Hello everyone i have this ST2000LM007 Drive which clearly gives me signs of head sticktion with sounds and Low current Spinning error in terminal,
Can someone guide me how to do head unsticks with these drives as i dont have any head unstick tools for this drive.
Thanks in advanced
ST2000LM007 Head Unstick
Re: ST2000LM007 Head Unstick
As it sounds like this is a client drive you are referring to, I suggest you not use their drive to learn on. Instead, you should purchase a few drives of the same model and practice your techniques. In the meantime, you should consider outsourcing the project to an experienced lab partner who will have a better chance of getting your client's data in this case.
thanks for the kind advice first of all.. i have 3 extra drives which i have done head replacements few weeks back. this is the first time im dealing with a head stuck in LM007 head stuck issue. can you give me and lil advice what is the safest method to begin with ?
You can slide the heads of one of your working drives onto the platters to replicate your scenario and then figure out how to get them back to the parking ramp without scratching the surface and/or ripping the sliders off.thedarkmask wrote: ↑Sun Apr 21, 2019 11:33 am thanks for the kind advice first of all.. i have 3 extra drives which i have done head replacements few weeks back. this is the first time im dealing with a head stuck in LM007 head stuck issue. can you give me and lil advice what is the safest method to begin with ?
You can also watch a video created by Amarbir of CDR showing the procedure - https://youtu.be/17XRilKm9FI
