One of the ongoing issues with NVME SSDs is that they are not easily connected to a system without the appropriate PCIe connections. Perhaps AData's new ASM2362 controller will be the answer to all our troubles.
https://www.cnx-software.com/2018/06/11 ... -ssd-chip/
NVME SSD to USB Adapter
Re: NVME SSD to USB Adapter
Hi....I have the same quest and just spoke to Startech. They make a lot of adapters. They expect to be able to have one for NVMe M.2 SSD to USB sometime this year. The representative at Startech said it's a hot item and nobody has one yet, as far as he knows.
Link Removed
Administrator note: if you want to promote your company on this forum, just be up front about who you are and make an honest post. Not use the exact worded post from other forums posted a year or more ago.
Link Removed
- CrazyTeeka
- Lurker
I've has good results with the "UGREEN M.2 NVMe SSD Enclosure USB C PCIe M-Key Adapter 3.1".
It uses the ASM2362 controller, and works with a WD SN750 500GB NVMe SSD.
