Page 3 of 6
Re: Log of Seagate DM Series Issues
Posted: Mon Oct 03, 2016 2:39 pm
Serial: W1E5...
Model: ST2000DM001
P/N: 1CH164-515
FW: CC47
Date: 14036
Site: WU
Number of heads: 4
Symptoms: none (from RAID)
Solution: bad sectors found while imaging
Posted: Thu Oct 06, 2016 8:50 pm
Model: ST3000DM001
P/N: 1CH166-300
FW: CC43
Site: SU
SN: W1F
# of heads: 6 (0,1,2,3,4,5)
Symptom: Scraping
Cause: Fatal Head Crash
Solution: None, DOA
Posted: Thu Oct 13, 2016 6:44 pm
Model: ST2000DM001
P/N: 9YN164-500
FW: CC48
Site: WU
SN: W1E
Symptom: Scraping
Solution: None, DOA
Posted: Mon Oct 17, 2016 2:38 pm
Model: ST2000DM001
P/N: 9YN164-568
FW: CC96
Site: WU
SN: W2F
# of heads: 5 (1,2,3,4,5)
Symptom: Scraping
Solution: None, DOA
Posted: Wed Oct 19, 2016 7:09 pm
Model: ST3000DM001
P/N: 1CH166-302
FW: CC26
Site: TK
SN: Z1F
Symptom: Inaccessible file system
Cause: Weak head 2, media damage, G-List issues
Solution: Cleaned heads, cleared G-List (got lucky that the drive only had 100GB of data). Head 2 reads worse as LBA increases.
Posted: Thu Oct 27, 2016 4:00 pm
Model: ST3000DM001
P/N: 9YN166-570
FW: CC9E
Site: WU
SN: W1F
Symptom: Drive clicking and not identifying
Cause: Weak head 4, media damage, media cache
Solution: Disabled media cache in module 93, set head for to read with really long timeouts
This drive is a perfect example of where many techs will mis-diagnose the drive and try to change the heads, only to make things worse.
Posted: Tue Nov 29, 2016 2:11 pm
Model: ST5000DM000
P/N: 1FK178-568
FW: CC48
Site: WU
SN: W4J
# of heads: 8 (0,1,2,3,4,5,6,7)
Symptom: Data not accessible
Cause: Weak heads / media damage
Solution: Diag Mode Locked, Unable to tweak FW, manually stitch an image together with DE
Posted: Fri Aug 18, 2017 3:22 pm
Model: ST2000DM001
P/N: 1CH164-505
FW: CC44
Site: TK
SN: Z1E
# of heads: 4 (0,1,2,3)
Symptom: In accessible drive
Cause: corrupt glist, head 1 stops reading after the first few percent
Solution: cleared glist, change heads
Posted: Fri Aug 18, 2017 7:29 pm
Model: ST3000DM001
P/N: 1CH166-505
FW: CC44
Site: WU
SN: W1F
Symptom: Inaccessible Drive gets stuck at BSY
Cause: Damaged glist, Head 1 reads fine for a few percent until it eventually is unable to read sectors
Solution: cleared glist, changed heads
Posted: Tue Aug 22, 2017 4:56 pm
Model: ST15000DM003
P/N: 9YN16G-302
FW: CC4C
Site: SU
SN: S1E
# of heads: 3
Cause: Damaged glist, Corrupt media cache, weak heads
Solution: cleared glist, cleared media cache
