Simple Guide to GNU ddrescue
Posted: Mon Aug 22, 2016 5:19 pm
You can find ddrescue here.
Show the disks via Linux terminal
> lshw -short | grep disk
Clone the drive
General example
> ddrescue {source} {destination} {logfile}
Image to file on mounted drive (ie, /mnt/destination) that has enough free space to hold the full image of the source drive
> ddrescue /dev/sda /mnt/destination/driveimage.bin logfile.log
Image disk-to-disk
> ddrescue -f /dev/sda /dev/sdf logfile.log
The -f switch is to force the overwriting of the destination drive. Without this switch, ddrescue will not permit a drive-to-drive clone to start.
Note: the logfile will be stored in the location from which the command was run. You can always specify the direct path to store the log file, if needed.
A few useful switches, should you need them:
Generate a log file (considers all non-zeroed sectors as being unread):
Switch: -g
> ddrescue -g {source} {destination} newlogfile.log
No data is read from the source or written to the destination during this process.
Image in reverse:
Switch: -R
> ddrescue -R {source} {destination} logfile.log
Retries:
Switch: -r {# of retries}
> ddrescue -r 3 {source} {destination} logfile.log
To view all possible switches:
> ddrescue --help
Once your clone/image has completed and you want to attempt a file system recovery, I suggest trying R-Studio. It is quite simple to use and supports most common file systems and RAID recoveries.
Re: Simple Guide to GNU ddrescue
Posted: Thu Feb 09, 2017 5:30 pm
You can use the GUI, making it more "fun" to work.
https://launchpad.net/ddrescue-gui
Posted: Tue May 16, 2017 5:47 pm
For those who want to take ddrescue to the next step and image only the sectors which contain files referenced in the MFT, there is another program that was designed to work with ddrescue in this way and has been out for quite a while.
ddrutility
If the drive is mostly full, there probably isn't much point in using this add-on. However, if the drive is less than half full, you could save yourself the time of mirroring unused sectors, increasing your chances of getting a clean recovery of your files.
