Opinions on soldering stations and soldering irons
A place where we can post about what we are seeing failing. Are you seeing a lot of a particular model of drive failing? This is where you would post about it and see if others are seeing the same thing too.
italyassistance
Post by italyassistance »
I need a soldering iron with a very thin tip to connect the wires of the microsd and sd with the pads, in addition to the well-tested JBC I found this, opinions? Has anyone ever used it? Advice for other valid and not too expensive models?
https://quick-global.eu/product/quick-t ... -aBvldTZ31
Re: Opinions on soldering stations and soldering irons
I got this one and it's very very good.
Search for SUGON-T21.
