Integrated RAID 0 mSATA SSD
Have an SSD from a Acer Aspire S5 or Acer Aspire S7 that just doesn’t seem to work when you remove it from your system? This is likely because you didn’t notice that the SSD is actually two SSDs on a single circuit board in a custom setup where they are merged into a single larger capacity SSD using RAID 0 striping.
What does RAID 0 (striping) mean?
The two SSD drives are merged together like a zipper at the sector level. The first 128 sectors are written to the first drive, the next 128 sectors to the second, the next 128 sectors to the first and so on. In order to recover the data, it is necessary to build a custom solution to allow interfacing with the second SSD. By striping data across two or more drives, the capacity and speed of the storage is improved significantly. Unfortunately, there is no redundancy with RAID 0. If one drive fails, then entire contents across all the drives is lost.
Some models of mSATA RAID 0 SSD from Acer Aspire S5 and S7 laptops known by Recovery Force, thus far:
Kingston SMSR150S3
Lite-On CMT-256L6M
Lite-On CMT-256L3M
Phison SSE256GTTCR-S80
Our team is equipped to handle the recovery of data from integrated RAID SSDs like these very quickly and at our base data recovery rate for a 2 drive RAID 0.
If you have an integrated RAID 0 SSD from any model of laptop, computer or tablet and are looking for a way to recover your data, contact the team at Recovery Force to find out how to find out how we can help.
SanDisk Professional G-Drive Data Recovery
We have started to see an increase in cases for Western Digital's equivallent of Seagate's LaCie product line, the SanDisk Professional G-Drives coming in for data recovery services. Inside the enclosure, we usually find helium filled Western Digital hard drives built...
Good intentions don’t always mean good results
Yesterday, I received a call from an end user who described an issue with his laptop drive that failed to fully boot into the OS he had just passed over to his company's internal IT. While the tech was trying to attempt data recovery, I explained to the customer that...
Data Recovery Triumph: 100% Retrieval from a 256GB Princeton SATA SSD with ASolid AS2258-BN Controller
Introduction: In the ever-evolving digital landscape, data storage plays a pivotal role in our personal and professional lives. When disaster strikes and vital data seems irretrievably lost, the role of data recovery experts becomes paramount. At our renowned data...
