R-Studio 9.2.191115
Discuss R-Studio and other products by R-TT
R-Studio 9.2.191115
A new version of R-Studio is available for download.
New features
+ Data storage types (SSD, HDD, USB, etc) info has been added to the Drives pane.
R-Studio Technician:
+ A new option "Skip files with bad sectors" has been added to runtime imaging of individual folders/files.
+ A new option "Unused clusters only" has been added to the multi-pass and complete runtime imaging options.
+ New file formats for recovery lists have been added: HTML, XML, JSON, and CSV. The new formats, especially the HTML one, allows the customers to easily edit recovery lists in their web browsers and then send edited lists back.
Improvements
* Speed for runtime imaging of individual files has been significantly increased, especially for many small files. (R-Studio Technician)
* Several tabs can now be moved by dragging them with the mouse.
* Processing of various non-printable characters in file names has been improved.
* Hints for shortcut menu items are now shown in the status bar.
* Search for and opening of file regions is now faster.
Changes
= Save/Load File Names menu items and commands have been renamed to Export/Import Recovery List.
Bugfixes
- The path to runtime image was processed incorrectly for runtime imaging on its dialog box. Fixed.
- Hardlinked files may have been recovered incorrectly. Fixed.
- The Estimated size value on the Create Image dialog window may have not changed when the Compression ratio slider was moved. Fixed.
- Files/folders with non-Latin names were not marked after recovery lists were loaded. Fixed.
- No read indicator (R) was shown on the I/O Monitors window while skipping slow areas. Fixed.
- All S.M.A.R.T. icons changed to green after a runtime image was connected. Fixed.
- Names of files which contained something similar to HTML tags may have been shown incorrectly. Fixed.
- Nothing was selected for the Copying mode options on the Smart drive copy tab in Drives Copy Wizard. Fixed.
- It was possible to clear the Enable write option even when runtime imaging was activated. Fixed.
- The program may have crashed when file sorting tabs were switched. Fixed.
ddrecovery
Re: R-Studio 9.2.191115
Post by ddrecovery »
Shame they cannot stop it crashing.....
